Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 08-14-2005, 04:31 PM
Double_D650 Double_D650 is offline
1995 Cutlass Supreme Stereo
hey i was wondering if anyone could tell me what color wire is what for the stereo of a 95 cutlass supreme. i know most of you are thinking "get a wiring harness" but the problem is that whoever had it before me cut off the stock harness so all i have are wires and no idea what is what. thanks for your help!
Old 08-14-2005, 09:08 PM
Jeremy86 Jeremy86 is offline
Send a message via AIM to Jeremy86
Re: 1995 Cutlass Supreme Stereo
I'm pretty sure my records are correct.. Try this:
FIRST COLOR IS THE VEHICLE COLOR*
*Left Front Speaker (-) Is Light Gray, your radio should be white w/black stripe
*Left Front (+) Is tan, radio is white.
*Right Front (-) Light Green, radio is Gray w/black stripe
*Right Front (+) Dark Green, radio is Gray
The ground is black, same with radio
Your head light dimmer wire is gray, on some radios if you have it, it's an orange wire on radio
Power Antenna Turn on (IF you have it) is Pink, and it would go to blue (I don't know if you have it or not)
The + 12 Volt IGNITION wire is Yellow, it will go to a red radio wire
Your CONSTANT +12 Volt Battery wire is Orange and it'll go to the Yellow wire
Your Right rear (-) is Light blue, will go to purple w/ black stripe
Your Right Rear (+) is Dark Blue and it'll go to Purple
Left rear (-) is yellow and it will go to green w/ black stripe
and lastly the left rear (+) is brown and will go to green on radio.
Hope this helps!
Aka 93 Cutty
Working on my next project: A 1986 Honda CRX. Little beater with lots of engine
Car Audio Freak
http://www.sounddomain.com/ride/613185
Old 08-15-2005, 10:56 AM
thanks for your help! very much appriciated.
Old 08-15-2005, 02:52 PM
no prob, hope everything works out
Aka 93 Cutty
Car Audio Freak
