i have a 1992 z28 and it always runs hot?? what is the normal temperature for this model?? the mechanics all say 220 is normal?? too hot for me. any suggestions?
Re: over heating
lower temp thermostat will get the water running earlier and should keep it cooler... Jet makes a chip that turns on fans earlier to help keep it cooler too... You might have a gunked up radiator? Maybe get a flush...
thanks.. i have a 195 in there now, what do you suggest?? i have a new 3 core all metal radiator, should be ok???? |
Re: over heating
220 is normal. And actually that's controlled temp where the fan(s) don't even kick on until 230-240.
I have a 180 stat and so long as the car is moving, It never exceeds around 190. In traffic, well I see the above. Don't forget aobut your radiator cap either! Although you said you got a new rad. which assume came with one. |
Re: Re: over heating
go with a 180, 160 is probably too low.
