Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 08-14-2005, 02:51 PM
rotary632 rotary632 is offline
EDIS igntion module location
Car won't start, engine turns but won't turn over. Changed ignition coils and checked for voltage. What I thought was the ignition module turned out to be, I guess the Cruise control module. The only thing i haven't tried is the ignition module but i can't seem to find it. can someone tell me where I can find it....Thnx 1996 Grand Marquis
Old 08-14-2005, 02:58 PM
reekor reekor is offline
Re: EDIS igntion module location
On my 92GM and 94CV it's on the driver's side outter fender near the firewall.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 08-14-2005, 03:26 PM
Re: Re: EDIS igntion module location
It's really weird, I know what you are talking about but it seems to be different on this car....The ignition module I bought matches the diagram shown on the manual but the location is different, I guess....HELP
Old 08-16-2005, 01:28 PM
Re: Re: Re: EDIS igntion module location
Well as this car is new to me, i've learned that it does not have an ignition module. It is all controlled by the PCM. It was suggested that the crankshaft sensor could be bad, causing the no start. Does any one else have any other suggestions or has come across the same problem.
Old 08-16-2005, 04:00 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Are you sure the spark is missing? How about fuel? Have you tested the fuel pressure? The crank sensor is a good possibility if there is no spark. Could be just a loose connection also. Good luck.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 08-16-2005, 08:36 PM
Angry Re: Re: EDIS igntion module location
I checked the connector that goes into the coil pack. The middle plug is 12v @ ignition switch on....the outer left is the signal when engine is turned on. There should be a signal at that point to the spark plugs. I test that with a test light to see it if flashed....it did not. So my assumption is that there is something or some sensor that is bad. I tried to change the crankshaft sensor, thinking it was a 5-10 min job seeing how small the sensor is. Man was I wrong, I looks like I have to take off the A/C compressor so the sensor can be fully pulled out. Unless some has a trick that prevents some much work....
