Go Back   Automotive Forums Car Chat > Buick > Century
Old 08-14-2005, 12:54 PM
magic man magic man is offline
not hitting on all cylinders
I have a 96 century that is missing on # 6 cylinder I have changed all pugs & wires & it has not helped any suggestions? thanks
Old 08-14-2005, 01:11 PM
V12Alp V12Alp is offline
injector, check the compression
Old 08-14-2005, 02:14 PM
public's Avatar
public public is offline
Re: not hitting on all cylinders
Ditto the injector. Try a couple of doses of fuel injector cleaner. Put both in at the same time, the 3.1 engine is known for this issue.
Yes, I am retarded.
Old 08-16-2005, 12:33 PM
pmmia pmmia is offline
check the ingention coil changed all three costed $20 each at autozone
Old 08-19-2005, 08:01 AM
public's Avatar
Re: Re: not hitting on all cylinders
Coils onthis car fire 2 cylinders each. So a coil usually will not cause one cylinder to miss. Perhaps if the plug wire connector broke off. :-)
Yes, I am retarded.
Old 08-21-2005, 03:04 PM
tri-power's Avatar
tri-power tri-power is offline
Right if the coil were bad then two cylinders should be misfiring. Also physically check the spark plug and make sure it isn't fouled or damaged.
Old 09-08-2005, 11:38 PM
dane_774 dane_774 is offline
do a compression check . if ok then sounds like a vacuum leak . normalally its the coil pack .remember if compression the gas then spark if all then it should run.
