View Poll Results: Should I try to fix or Junk
Should I try to fix 0 0%
Should I junk 0 0%
Voters: 0. You may not vote on this poll
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 08-14-2005, 11:57 AM
weberick weberick is offline
Contour 2.0 DOHC timming belt Crank problem
I have a 1999 with the Contour motor that chews up timming belts, pulles etc. The shop tells me there is play in the crank which causes this problem. Any ideas?
Old 08-15-2005, 01:43 AM
OverBoardProject OverBoardProject is offline
Banned
Re: Contour 2.0 DOHC timming belt Crank problem
If you can pull the oil pan easily enough you should be able to replace the bottom end bearings easily enough. This job is usually pretty easy on a fwd
This should cure your problem.
But look into a good manual like Haynes first, since there is a small chance that they use shims to hold every thing tight
Old 09-27-2007, 08:16 PM
ksdunlap ksdunlap is offline
The DOHC with the VCT the exaust cam gear is cocked a little side ways causing the belt to ride out on the gears. and the medal bracket that is between the cam gears and crank is chewing up the belt. Just ran acrossed that problem this week.
Closed Thread
