Go Back   Automotive Forums Car Chat > Hyundai > Sonata
Old 08-14-2005, 08:52 AM
bggas400 bggas400 is offline
No air
Hi,
Before I take it to the dealer @ $90 per hour, I figured someone might have an idea.
I have no air coming out at all, be it hot or cold air.
The fan/blower does not come on but when I turn the dial (0 -4 for amount of air) but sometimes I can feel the engine 'bog' down a bit. So I'm not sure if it's electircal, the blower?
Certainly I can handle no cool air in the summer but I must fix it before the winter.
Thanks for any ideas
Barry
Old 08-24-2005, 08:04 AM
SteveB05's Avatar
SteveB05 SteveB05 is offline
Re: No air
Check the fuses. It sounds like the compressor may be coming on, so you could just have a blown fan fuse. Could also be a bad fan switch or blower motor.
Steve
'98 JGC (ZJ) 5.2L, Aluminum Radiator w/Electric Fans, 4" Cowl Induction Hood Scoop, Custom High Flow Air Filter, Magnaflow Cat / Flowmaster Super 40 Exhaust, Engine Oil cooler w/ remote filter, In-roof 8" DVD, Profile 600 Watt Amp, Kenwood 6.75" 3-ways, NV242, 3.5" Lift, RS9000s, 31x10.50x15 ATs, Proline roof rack w/ spare tire mount and 4 Hella 550s.
Old 10-26-2005, 03:09 PM
Re: Re: No air
Hi,
I've checked the fuses and all is ok. A mechanic said the blower motor is ok and mentioned that it is probably the fan switch or the 'head' so he will need to take the dashboard apart.
Is there documentation or a manual that you can point me at that will aid me in removing the middle piece of the dash?
Thanks,
Barry
