Go Back   Automotive Forums Car Chat > Renault > Clio/Clio II/Clio III
Old 08-14-2005, 07:50 AM
paulfsi paulfsi is offline
Clio 1.2 - speedo innop - poss speed sensor
Hi there.
Friend of mine has a 1.2 clio.
Its a clio 2, phase 1.
I have had the dash top off to check the wiring is plugged into the speed counter itself, this seems ok.
Where is the speed sensor? I am sure it must be on the gearbox rather than on the brakes?
And i am not sure if the cars abs is working as it skids to a stop rather than the pedal juddering?.
The speedo sometimes flicks up to 7-/80 when on a dual carriageway but then dies off, also we had it working for a few minutes all over the speed range (proper operation) but we got to 50mph and it died again.
Im wondering if this is more of a wiring fault myself..
There was a blown 30AMP fuse in the engine compartment fusebox.
I fear the sensor maybe intermittently giving a reading rather than constantly giving a feed - but i need to know where the sensor is?
Thanks very much for any help / tips,
Paul
Old 09-10-2005, 11:04 AM
Shortie Shortie is offline
Re: Clio 1.2 - speedo innop - poss speed sensor
The sensor is down the back of the gearbox, its a black plastic unit with the wiring plug on the top, it can be reasonably easly removed.
Fuse F9 under the bonnet is for ABS.
