Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 08-13-2005, 10:17 PM
Olona Olona is offline
Thumbs down Speedometer will not illuminate
1985 TBird speedometer does not illuminate, fuses all look good, can some one please help me?
Old 08-13-2005, 11:16 PM
Jim Adams Jim Adams is offline
your headlight switch is bad,,there is a way if you are mechanical to jump from the hot on wire in the switch to the wire going to your acc,s (radio ,cluster heater controls ect.. ),,if your other acc work then the wire going to the cluster is broke or bad connection and you can jump into the lights on the cluster the same way by bypassing the incomeing wire from the switch if it is broke.,,take the cluster out flip it around track down the wire or the spot where wire makes contact with alumination copper(kinda like a road map of the lights on the back of cluster) then take a jumper from hot on or dimmable hot on and jump it into the plug where it will make contact with the alumintation copper.
Good Luck!!
P.S. Post to me if you need Help!
Old 08-13-2005, 11:24 PM
Re: Speedometer will not illuminate
Would it be easier to replace headlight switch?
Old 08-13-2005, 11:29 PM
yes it would if infact that is the problem,,but if your radio and your heater controls light up with the switch then it is not the problem
Old 08-13-2005, 11:31 PM
I see said the blind man!
Old 08-13-2005, 11:34 PM
check it out and if you need help jumpin wire into the cluster give me a message and I will walk ya threw it,,,if you dont need a switch,,good luck!
Old 08-13-2005, 11:40 PM
Thanks, my e-mail address is [email protected], would you happen to have a wire diagram and or a fuse panel diagram for this TBird?
Old 08-13-2005, 11:59 PM
I will get a wire diagram off line so I can tell you which wire to come off of on the switch and which wire to go into in the back of the cluster,,my email and screen name >> [email protected],,I will put you on my buddylist for when I get the diagram and you are ready to fix it
Old 08-14-2005, 10:48 AM
flewthecoupe's Avatar
flewthecoupe flewthecoupe is offline
Re: Re: Speedometer will not illuminate
as he picked up the hammer and saw.
It's not how fast you can go, it's how fast you can get there.
Proper grammar, it's not just for English teachers.
I don't pick on any one person, I treat everyone this way.
My only pleasure is tormenting those people who work for me.
There are no stupid questions, just a lot of inquisitive idiots.
