Old 08-13-2005, 07:57 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Exclamation Reverse Glow Gauge Problem?
I installed some reverse glow gauges the other day. In order to get them on, you have to take off the little needle. I then put the needles back on about where they naturally fell when I took them off. I notice the RPM is off, and I think the MPH may be off also. Is there anyway to put the needles back on right? Or is it all by trial and error? Thanks
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 08-13-2005, 08:05 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: Reverse Glow Gauge Problem?
I think its just trial and error. the RPM and MPH badging on the aftermaket glow lights might be your problem. I would suggest taking it off and reverting it back to stock just to see if everything gos back to normal. Sorry, I know thats not very helpfull, but its the only suggestion I have.
DSM geek
Old 08-13-2005, 08:13 PM
david-b's Avatar
Dave is THAT guy
It works fine. The needles move and all. To install the stock backing, i would have to take the needles off again and still ahve the same problem... did I put the needles back on where they go? Im going to drive behind my bro and keep the same speed. I know the RPM is 200 too high.
75 Monte Carlo
Old 08-13-2005, 10:10 PM
Killa's Avatar
Killa Killa is offline
the gauge I bought 3 year ago ( still work perfect ), When I install it do not need to remove the needles ( I hook the gauge to my fog light I guest ,
Old 08-13-2005, 11:08 PM
I have no idea. Sorry. The only thing i can think of is asking a Guru, and unfortuitly were fresh out of them on this site right now. <shrugs sholders>
DSM geek
Old 08-14-2005, 12:59 AM
slideways240's Avatar
slideways240 slideways240 is offline
Send a message via MSN to slideways240
just start your car, do you remember where it normally idled? i did this to my 240 and had the same prob. like i said start your car if you dont know its old idle then just guess. turn the needle down a tid to about 800 or 900. thats usually what my car idled sometime 1000. an jus toy with it like that til you get the needle to float right. its pretty simple. the speedo however is a lil more difficult. what you gotta do is get a friend go down a pretty straight road. highway/interstate works good. if you got cruise it works better. set the cruise or if not just try holding your speed have you friend motion your speed or cell phones work good. now turn the needle in the direction it needs to go. its all relatively simple...if your confused just pm and ill give you my # and maybe explaining over the phone will be easier.
Old 08-14-2005, 08:56 PM
david-b's Avatar
Dave is THAT guy
I fixed the idle. Kept the plastic clear cover off and then adjusted it. Just about back to normal. Just have to do it with the MPH now. GOing to drive behind my boy doing 30 and then flip on the cruise.
Quick question to verify... when you're in 5th gear at 2000rpm, how fast are you going?
75 Monte Carlo
Old 08-14-2005, 09:13 PM
mitsu_eclipse95gst's Avatar
mitsu_eclipse95gst mitsu_eclipse95gst is offline
lol have you ever maxed out your car? If so do it again and see how much it's off lol j/k
1990 Mitsubishi Eclipse GSX
1995 Mitsubishi Eclipse GS-T (SOLD)
2002 VW Jetta 1.8T
Old 08-14-2005, 09:29 PM
david-b's Avatar
Dave is THAT guy
LOL. Nice. Whats it max out at... 130 something? Fastest I ever got was 120. Only 1 that happened.
75 Monte Carlo
Old 08-14-2005, 09:34 PM
I'm not sure what the RS/GS max out at.. I'll have to do some searching on that one
2002 VW Jetta 1.8T
Old 08-14-2005, 09:35 PM
Oh i just thought of this.. Do you have any of them speed things around? Not sure what they are called. Anyway drive bye that thing a few times and set it off that.
2002 VW Jetta 1.8T
