Old 08-13-2005, 07:45 PM
Riceboy891's Avatar
Riceboy891 Riceboy891 is offline
Question Sohc ZC probs/questions
So i just put a sohc in my 1990 std hatch. It previosly had a dohc zc but spun a bearing twice. Anyways i put the motor in and realized that the driver side motor mount does not fit. Then i noticed the ditibutor plugs were different. This led me to believe that the motor is an obd1 version. So i put my old obd0 injectors in but the obd0 distributor mount holes are different. So what can i do to make this work? Can I put a 92-95 civic drivers side mount on it and drill and tap new dizzy holes? Any help is extremely apreciated.
1990 Civic HB
DOHC ZC *RIP*
SOHC OBD1 ZC
ZC Tranny
P06 ECU
Stage 1 Clutch
I/H/E
B&M Short Shifter
14" Integra Wheels
KYB AGX Shocks/Tein Springs
"yeah but it has most all of that hp and torque though the entire rpm range, where as a honda, have to be revving high enough that only dogs can hear your motor to make numbers" -TheSilentChamber
Old 08-14-2005, 10:19 PM
BiGwiLLswiLLy BiGwiLLswiLLy is offline
Send a message via AIM to BiGwiLLswiLLy
stock 4th gen mounts should work and dont drill holes that would be bad...you can use big washers to hold the dizzy down if u get how im tryin to describe it...there is a post if u search with pics of the dizzy mounted usin washers
Old 08-15-2005, 02:44 AM
89ZCCivic's Avatar
89ZCCivic 89ZCCivic is offline
Re: Sohc ZC probs/questions
dude is your sohc zc motor similar to this one (http://cgi.ebay.com/ebaymotors/1988...Q cmdZViewItem) couse im also thinking of changing my dohc zc for the sohc zc vtec. i trying to figure out if the sohc motor will just drop in to my 89 hb without having to chane stuff
