Old 08-13-2005, 07:53 PM
KevinG KevinG is offline
Need some help guys!
Just read in another thread about a guys problems that are exactly the same as mine. His problem was:
Well...to make it as short as possible, the service engine soon light is on, and sometimes blinking. The car shudders when I accelerate and has lost a lot of power. The gas milage is down about 3 miles per gallon. It also has a rough idle. When I put fuel system cleaner in it gets a little better, but not much. Also, when I have the computer read, the error is a misfire in cylinder 5 and 6. I just had new plugs and wires put in about 10,000 miles ago. I also notice that the tachometer is a little jumpy when I am idling and the engine surges a lot.
Mine does the exact same thing. Someone said it could be a bad coil, to what coil are you refering to? Can anyone post a link on a replacement?
Old 08-13-2005, 07:59 PM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
Alright man, your car can have ANY of these going wrong with it.
Need a new Igntion Control Module (ICM), Throttle Position Sensor (TPS), also you should of had replaced your filters when you changed the plugs and wires.
Old 08-13-2005, 09:12 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: Need some help guys!
I am going to agree with Rally on this, I would put my money on it being a ICM, thats the only thing that works with both the tach and the coil firing. If it was your coil, most likely it would not effect your tach. What engine and year are we talking about here though.
John
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 08-13-2005, 09:17 PM
J.Cutta's Avatar
J.Cutta J.Cutta is offline
In addition to the ICM and TPS change the Idle Air Control Sensor and that should fix the rough idle.
http://www.cardomain.com/ride/631458
_______________
92 Camaro V8 TBI 305 with Dynomax 3" Catback Exhaust, ASCD Iroc Turbo Hood, Goodyear Triple Tread Tires, K&N Open Element, Cat Delete, WonderBar Steering Brace, 160 Thermostat
Old 08-14-2005, 01:29 AM
Is eating.
No it wouldnt, it isnt broken. If it needed to be replaced the car would die when its just sitting there. But it's just bouncing up and down crazy like means its the ICM.
