| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
I have a serious problem.. i Just bought this 91 talon awd toady and the main problem is the idle..
I start it, no matter cold or hot, and it goes right to about 2,000 rpm, and then it surges, fluxuating from about 2,000 to 2400, and then to about 1800, back to 2000, etc. etc. its weird and its annoying. There is an exhaust leak somewhere near the downpipe and cat, but thats it, its not really a leak, sounds like there not connected, but i dont see that as any kind of diagnosis for the idle problem.... PLEASE, ALL HELP IS GREALTY APPRECIATED, Thanks, Shawn |
Re: 91 awd talon HIGH IDLE SURGE
Welcome to the site! Do you have any intentions of replacing the Stock Exhasut with an aftermarket exhasut, or just fixing the problem Now, and thinking about it later?
I dont beleve exhasut leaks cause idle problems, the 02 on the 02 housing is what reads the lean/rich mixture. I would suggest resetting your Bliss screw on the Throttle Body. Or even dissconnecting the battery to reset the ECU. Go onto ebay and buy the 5 dollar DSM service tech shop manuals on CD-ROM, it will help you emenecly. Sorry Im short on time right now. or i could tell you how to do it..
DSM geek |
Sounds like u have a vacume leak
Vfaq.com Will Help You. Look Under Engine, Then Idle Surge. Im Almost Positive That Will Help You
v-cum leak
91 Eclipse GS 5-Speed 2.0L DOHC 16 Valve (Black) Stock 93 Eclipse GS-T 5-Speed 2.0L DOHC 16 Valve (Red) Cosmo Racing Air Filter Brembo Rotors 14b turbo Faze Boost Gauge Faze Air/Fuel Gauge Dual Gauge Pod Megan Racing 3" turbo back exhaust 450cc Injectors I am selling my 1993 GS-T eclipse for 3000 obo. it has a new engine with 15,000 on it, brand new 3" turbo back exhaust, Brembo rotors, and NEW Faze A/F gauge and Boost/Vac Gauge. will post pics as soon as I can PM if interested |
Try manually operating the throttle. See if you can lower the idle by closing the valve. I had the same problem on a 95 Tsi. I took off the throttle body cleaned out the carbon residue which was making it stick then added a spring from canadian tire ($1.50) to the exterior to help close it. Be sure to only use the minimum strength spring you need to close the valve all the way. She hasn't acted up in 3 years. You'll find the gas pedal more sensitive. Especially on and off the throttle, but I find that shifting greatly improves. The engine drops RPMs quicker between shifts. Good luck with your problem.
95 Talon Tsi AWD 5spd 2.4L4G64 6bolt JE8.5EagleTorqueplatedFully ballanced-balanceshaftARP Ferrea1mm 1Ghead ported/polished HKS264/272 fidanzagears turbonetics copy polished GT3076R VbandTial38mm cometic prothane mounts SARD850 stage4 Compclutch+flywheel 3"exh Walbro255 rewired Innovate wideband O2 ForgeBOV Autronic standalone innovative wideband[url=http://img494.imageshack.us/my.php?image=talonandhelicopter5as.jpg]
