Old 08-13-2005, 06:08 PM
camaromaniac camaromaniac is offline
turn signal/ high beams
i have a 91 z and the heam beam switch is broke, how do i replace that? also, my right turn sig doesnt work rite. when i turn it on, instead of blinking it just stays on continuously. but it does blink when i use the hazard ligts. any suggestions?? thanks
Originally Posted by Rally Sport 92
Dont get me wrong though i'd love a Lt1 in my Camaro even if it had Richard Simmons strapped onto my hood naked..
Old 08-13-2005, 07:44 PM
Morley Morley is offline
The highbeam switch is located on the column on the left side about half way down. When you replace it, tape the actuating rod going to it to the column.
Turn signal might be the blinker or a burned out bulb.
Old 08-13-2005, 09:36 PM
J.Cutta's Avatar
J.Cutta J.Cutta is offline
Re: turn signal/ high beams
As for the light not blinking either your front or your back light bulb is not in all the way. Most then likely it is the front. Make sure you push down then twist it into the grove.
Also if your high beams dont click on try tilting the wheel all the way up then it should click.
I had these same problems
http://www.cardomain.com/ride/631458
_______________
92 Camaro V8 TBI 305 with Dynomax 3" Catback Exhaust, ASCD Iroc Turbo Hood, Goodyear Triple Tread Tires, K&N Open Element, Cat Delete, WonderBar Steering Brace, 160 Thermostat
