Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 08-13-2005, 05:49 PM
ndngoddess67 ndngoddess67 is offline
Angry wiring harness
hey ... I was wondering if anyone knew the dif between the "F" and "G" wiring harness for the 99 cougar....or maybe have a schematic of what the dif colored wires were....help....engine swap not going to well
Old 08-14-2005, 12:32 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
what seems to be the problem? Is it not the same harness or what? Everything should just plug into its original locations. Why is the original harness not being used?
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 08-14-2005, 06:02 PM
Re: wiring harness
the original was burnt in a fire...no everything is not plugging up because we have the G harness and we need the F harness..hence the reason we would like to know the dif between the two
Old 08-14-2005, 07:31 PM
I would say one is a returnless harness and the other is a return. Thats the only differences I know between harnesses.
The differences between the two harnesses are:
-Returnless has an extra fuel pressure transducer connector
-knock plug sensor connector
-all 6 injector plugs connectors
-both front bank 02 sensors connectors
-oil pressure sensor connector
"The CEG Nazi"
www.contour.org
