Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-13-2005, 04:11 PM
GTPSPEED GTPSPEED is offline
BOSTONjoe98gs
burned wires,some advise please
ok,today its real hot here in boston and i was driving and my battery light went on but went away then as im driving my car dies,i try to start it and nothing no ticking noise nuthing,all the rest of the lights and stuff work ok but as i poped the hood i noticed these wires that are clipped on to the front of the valve cover that my intake are pressed against well the intake was mad hot and it looked like it melted the outer coating of those wires,so now the car wont turn over no tick no noise nuthin,any idea what this could be or why it wont start now or what those wires are for,thanks,,,ps. its a 98 gs auto thanks
2000 GRAND PRIX GTP RED 14.345 @97.8mph
ubend delete
3in jimmyC downpipe
magnaflow high flow cat
Joeflo CIA (made it myself)
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
ss 409 xl turbo mufflers
Old 08-13-2005, 06:09 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: burned wires,some advise please
In front of the valve cover on the intake side? Like right by the battery? You could have a major problem there. Do they go right to the battery?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 08-13-2005, 07:51 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
If your starter is working (clicking) then your alternator, or battery is bad.
DSM geek
Old 08-13-2005, 09:24 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
It could have crossed the wires and caused a short. Fix the wires and check all your fuses (i had a similar problem not too long ago)
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 08-14-2005, 07:23 AM
BOSTONjoe98gs
i get no clicking,and the wires dont go directly to the battery they are closer to the other end of the intake near the filer but they clip to the front of the valve cover my machanic said he got it started when he jumped it but after he shut it off there was nuthing again
ubend delete
3in jimmyC downpipe
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
Old 08-14-2005, 12:21 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
A picture would be helpful so we know exactly where these wires are.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 08-14-2005, 03:11 PM
BOSTONjoe98gs
see in your sig right near the heat shield that clip,thats on top of the engine,those wires i cant take a pic cuase its at the shop
ubend delete
3in jimmyC downpipe
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
