Old 08-13-2005, 03:59 PM
Silverado Brethern's Avatar
Silverado Brethern Silverado Brethern is offline
Engine rebuild
I want to rebuild my engine this winter/next spring and need to start getting some prices together. I want to get new pistons and rings, a new cam shaft lifters and timing set, new heads or have mine ported and polished (whihc would be better?), new intake, and then sometime before i put the engine back in i wanna throw on some headers. Is there anything else that is a must when rebuilding an engine? i already have a new water pump bought. Anything else necessary to get done? other than machine work to the block and crank.....
"Never under estimate the power of stupid people in large groups."
1997 K-1500 Silverado Vortec 350...125,610 and wounded
HD chassis package
Custom TRUE DUAL exhaust with cut-outs and Flowmaster 40 series mufflers
Poweraid Throttle Body Spacer
Custom Ram-air Intake with K&N FIPK GEN II
TFES Performance 3" Suspension Lift
Dual Air-Horn Kit with Compressor
Bed-Mounted 48" Hi-Lift Jack
Cobra Laser Radar Detector
285/75/R16 Cooper Discoverer STT's
1/4 Mile 10/15/05: 16.43 @ 91mph
Old 08-15-2005, 07:12 AM
Slowprocess's Avatar
Slowprocess Slowprocess is offline
Send a message via Yahoo to Slowprocess
Re: Engine rebuild
I think you posted before...but what kinda specs are you looking at for everything?
Daily Driver- 00 Camaro SS A4 1/4- 12.30@118mph 2.14-60ft on street tires
Weekend Warrior-99 Silverado "Dirty" 1/4-11.63@118mph 1.8-60ft
Old 08-15-2005, 05:45 PM
Re: Engine rebuild
Well im not highly knowledgeable about engine internals and what not, so i would like to try to keep things as simple and basic as possible. I have not looked into the detailed specs on all parts yet. Im just tryin to figure what all i want/need for pricing and then ill narrow it down to what will work right.
HD chassis package
Old 08-15-2005, 06:11 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
Re: Engine rebuild
Might ought to think about taking it to a shop.
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 08-15-2005, 08:37 PM
Re: Engine rebuild
Yah that was my basic line of thinking. My dads friend is a retired mechanic who used to build engines a nascar truck series team so i figured he could give me help if need be. I plan to take it apart then get him to help me figure what will work best together and then if i cant get it all back together right ill trailer it to a mechanic and let them get it running right.
HD chassis package
Old 08-16-2005, 07:55 PM
NoRiceHere01 NoRiceHere01 is offline
Re: Engine rebuild
the first thing u need is a haynes manual. the biggest mistake people make when building engines is that they just get the parts and bolt them together. definitely get this engine builder guy to help u. people forget about checking clearances like piston ring gap, crankshaft end play and so on. theres more than just bolting on heads and such. but as far as other things u need, dont reuse old valve springs. get new freeze plugs. and dont put too big of a cam in the engine. i hate that lol. hope it goes well.
