Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 08-13-2005, 02:47 PM
starlem starlem is offline
Question No spark 92 delta 88
it has all new icm,coil pack,alternator,crankshaft sensor,camshaft sensor. still no spark i am getting codes 42 and 58
it was running were you could dive for about 20mins it would then
shut down and you have to waint for half an hour to a hour to go
agian. i had the crankshaft sensor changed and it made it two blocks
and wont start. please help me
Old 08-13-2005, 02:54 PM
tri-power's Avatar
tri-power tri-power is offline
When you changed the coil, did you also change the icm? And if you did, did you put the wires in the right order?
Old 08-13-2005, 03:08 PM
yas the wires are in the right order do you think my crankshaft sensor whent bad agian do you know what code 58 is the haynes manual say thare is no code 58
Old 08-13-2005, 09:49 PM
Jim Adams Jim Adams is offline
code 42 is a ignition control circuit grounding ,,you need to change the control module under your coils and the code 58 is your vehicle antitheft system fuel enable circuit and will either shut your fuel pump off or it will clear after you replace the module under coils and clear the computer by disconnecting battery and depressing the brake pedal 3 times ,,waiting 5 minutes and reconnect battery,,,also do you have a chip in your igntion key,,,If nothing works you may have a bad key and it has tripped the security in the vehicle,,try a spare key if you have another,,the chip in key can go bad if you have like a shoprite savings thing on your keychain that they scan to give you a discount at the supermarket it demagnitizes the chip in the key,,Good Luck!!
Old 08-14-2005, 02:01 AM
i pot a control module in still no spark key is good no more code 58 just 42
Old 08-14-2005, 08:44 PM
Thumbs up
put in another crankshaft sensor and it is good to go now i guess i got tow bad sensors thank you for your help
