Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-13-2005, 02:36 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
ticking
I have a ticking noise when I first turn on my car after it has been sitting for a while. After running for a few minutes it goes way and isn't heard again until I start the car after it has been sitting for a while. It only ticks in the lower rpms at first gear, maybe lower second. But like I said it never lasts very long. Any ideas, or should I not be worried about it?
1991 GSX 2.3 Stroker
Old 08-13-2005, 07:47 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: ticking
Could be your Evaporation Contole Sensor, or basic lifter tick.
Got both on mine, not to mention bad AC belt that squeks. Im sure you've poped the hood and located it, where is it comming from?
DSM geek
Old 08-14-2005, 12:15 AM
defiancy's Avatar
Re: ticking
Considering I don't have an ac belt, I know it's not that. I cut that belt off long ago when my compressor took a crap on me. As for those other two things. I have no idea what they are.
Old 08-14-2005, 12:20 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Since it only ticks when you first start the car, that makes me want to say that the oil pump may be going bad. You may not be getting enough oil through the engine and to the head, but as it warms up the ticking goes away because the oil gets hot and thins, making it easier to pump. Either that or you have the wrong grade of oil. Common lifter tick is also a possibility, it happens to a lot of DSM's.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
