Go Back   Automotive Forums Car Chat > Mitsubishi > Mighty Max
Old 08-13-2005, 01:49 PM
FD5 FD5 is offline
92 Mighty Max won't start
Won't turn over, there is a clicking noise coming from the passenger side floorboard kickplate area. Any ideas??
1992 Mighty Max
Independent Amsoil Dealer
Old 10-22-2005, 05:10 PM
mikelly7 mikelly7 is offline
Re: 92 Mighty Max won't start
I am having the same problem. According to the Haynes manual, the battery terminals could be loose or need cleaned. The battery may be drained or faulty. Next is says to make sure you are in park or neutral. Then inspect wires on starter circuit including solenoid and ignition switch. The last item says that engine could be seized.
I tried the battery terminals without success, but I am not a mechanic so I am not sure what to try next. Good luck - let me know if you get any results
Old 10-23-2005, 09:56 AM
FD5 FD5 is offline
Cleaned terminals on battery, checked all wire connections, still nothing. Turns out it was the starter, 39.95 at autozone for lifetime warranty starter, truck running fine now.
1992 Mighty Max
Old 12-05-2005, 08:30 PM
Starter for me also. Thanks. Soory for the late reply.
