Old 08-13-2005, 12:56 PM
JJH3 JJH3 is offline
Disassembling a model
I just recieved a model from ebay which was partially built and i was wondering what was the best way to disassemble the model in order to paint it and then reassemble without messing up the model completely. Thanks for any help.
Old 08-13-2005, 01:03 PM
SupaMan89T's Avatar
SupaMan89T SupaMan89T is offline
Send a message via AIM to SupaMan89T Send a message via MSN to SupaMan89T Send a message via Yahoo to SupaMan89T
Re: Disassembling a model
stick it in the freezer over night it will make the glue unbond and youll be able to get it apart easy
Project Lexus Revive
Old 08-13-2005, 01:12 PM
drunken monkey's Avatar
Razor Sharp Twit
does that work if the model is cemented/plastic welded...
Old 08-13-2005, 01:28 PM
cfcrules's Avatar
cfcrules cfcrules is offline
There is a paint remover, a kind of paste, that only removes enamel paint, that also removes the cement.
Old 08-13-2005, 05:06 PM
g00eY's Avatar
g00eY g00eY is offline
welcome to AF!
Old 08-14-2005, 06:42 PM
Thanks very much for all your help. I'm in the process of disassebling it now and so far so good.
Old 08-14-2005, 07:57 PM
Vric's Avatar
Vric Vric is offline
Use the inscruction manual, but start from the end
Old 08-14-2005, 09:41 PM
druid_99's Avatar
druid_99 druid_99 is offline
Re: Re: Disassembling a model
Dip it into water first before sticking it into the freezer... it works like a charm and with no parts breaking (if you're really careful). It works eventhough it is cemented/plastic welded (I've tried it...)
What is understood need not be discussed
Old 08-16-2005, 03:59 AM
klutz_100's Avatar
small extra tip: after wetting the kit, freeze it IN A PLASTIC BAG. It catches any small parts that might pop off and sops you loosing tehm amongst the burgers and fries
