Go Back   Automotive Forums Car Chat > Ford > Contour
Old 08-13-2005, 08:14 AM
twistedjessy twistedjessy is offline
Angry contour makes weird rattling noise...HELP
I have a 96 contour that has already had a new motor put in 3 months after I got it. I started to notice a rattling noise when i hit the gas a few months ago and thought that it might be the sheild on the exahust. I must have been outta my mind to think it was that simple. it constatly makes the noise now while driving, from the top of the car it sounds like its comming form around the altenator but my belt doesnt squeal and i dont lose any charge. It gets louder and more consistant if i use the AC or the heater. Any ideas?
Old 08-13-2005, 03:44 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
a bat cat immediately comes to mind. Sorta sounds marbles in a can. Could be a busted motor mount too.
Do you have a V6 or I4?
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 08-14-2005, 07:35 AM
no, its not a motor mount they are new too. i think it has something to do with the heat or AC, 4cyl DOHC
Old 08-14-2005, 05:50 PM
Re: contour makes weird rattling noise...HELP
does it get louder as your accelerate or does it eventually go away?
"The CEG Nazi"
www.contour.org
Old 08-20-2005, 04:57 PM
oldspower_68 oldspower_68 is offline
I'm a ford tech and have seen a number of idler pullies on the timming belt make noise from that area. or one of your accessory pullies. try running with belt of and see if noise is still there(don't run it long) if it is I would guess its time for a new timming belt and pullies
MatthewMatthew
