Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-13-2005, 04:53 AM
ffwv ffwv is offline
Eclipse can't swim
Last month my 18yr daughter decided to take her Eclipse through some water running across the road. She had a cold air intake and it went completly under the water. This caused the motor to be sucked full of water. When I opened the butterfly on the intake the water was sitting level in the intake. I got the water out and changed the oil and by some miracle it started. Since then, when she stops at a stoplight the idle slows down to almost nothing. It doesn't quit though. Then it surges up. When it does this there is a little bit of black smoke come out of the exhaust. Her gas mileage has dropped from 21 to 15. Had it scanned at Autozone. That showed random cylinder misfires. They suggested replacing the coil pack. Is this the first thing to do ? Thanks
She has a 98 non-turbo.
Old 08-13-2005, 09:12 AM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
Re: Eclipse can't swim
Check the plugs first and the wires, if it keeps doing that then I would recommend going with what autozone said.
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 08-13-2005, 12:24 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
My guess is that you fried something electrical under the hood when she went through the water. First check plugs, wires, and coil pack. Make sure there is no water sittin the the spark plug wells. After that, check the o2 sensor and the idle control sensor. If you really can't figure it out, take it to a dealer and have them run a quick diagnostic test.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 08-13-2005, 07:56 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
I also recomend replacing the plugs and wires. Random missfire codes are 90% of the time those two parts. Coil packs should throw a specific CEL code.
DSM geek
