| 240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all. |
z blasphemy
this is a hypothetical and last resort question?
recently on top of the wrecked1990 300zx that i just aquired, i also bought a 1990 nissan maxima, that at specs has a compatible block. now the 300zx has 222 hp while the maxima has 160, if i could not repair the damage to the 300zx could it be at all possible to put the innards of the 300zx into say the maxima chassis to provide the additional horsepower?? because as of now it seems the engine is pretty much a boosted version of the maximas? i do realize the maxima is fwd and that the z is rwd but shouldnt the mounts be compatible? also if this be the case, could the innard of say the maxes engine be fitted into the 3oozx block to get around the high compression issues with fitting an aftermarket turbo onto it? thus lowering the compression ratio and allowing for an aftermarket boost solution?
my cars were all wrecks before i fixed them, because of this simple fact i love,respect and enjoy them more than most drivers do on a daily basis. |
Re: z blasphemy
well, if i am not mistaken, the 1990 maxima has a VG30E in it and the 1990 300ZX has a VG30DE in it, so i know that the maxima is SOHC and the Z is DOHC, now, about the pistons, rods, and crankshaft being exchangable, it *might* be, but very unlikely.
![]() ZedEx Crew Member #2
Re: z blasphemy
... Man you're talking some insane fabrication work. I don't know what to think about this one, it seems a bit pointless to me.
-Wes
-2000 PY Acura Integra Type-R #686 - WhoRe -1997 EGP Honda Prelude Type-SH - Daily driver R.I.P Hypsi87:Andy Filson
lots of custom work...
we are talking swapping cross-members, custom tranny mounts, motor mounts, everything... too much money and not worth it at all. you have to remember...the maxima is a FWD car and the 300zx is a RWD car. making everything work for either or would take alot of fabrication with the crossmembers and mounts and trans configutation
ZedEx Crew Member #4
Re: z blasphemy
i have a friend who took a wrecked turbo porsche 911 or 944 and then put the guts into a vw golf mk 2 frame.
maybe too much work, but if i cant fix the frame. ill be darned if im going to let that engine go to waste. thanks guys
Re: Re: z blasphemy
Re: z blasphemy
Once again... If you feel you're up for the challenge, by all means give it a shot.
And I believe the 1990 Maxima's had a VH30E in them... Don't quote me on that, I can't remember exactly. So if you want to give it a shot, go for it. I wouldn't touch the project though. -Wes
Re: z blasphemy
blocks are identicle inard are different from the compresion of the piston size additional horse is from the obvious dohc ( which has vvt (variable valve timing), correct me if im wrtong there), inj, and ecu. are they both either auto or std? if so you may be onto something
note auto ecu works for manual but manual ecu wont work for auto (electronic shift sellinoids) good luck |
Re: Re: z blasphemy
i really have tried...i am beginning to think it is a lost cause.
Re: Re: Re: z blasphemy
Re: z blasphemy
... I read it about 15 times... I'm lost as well.
![]() -Wes
Re: Re: z blasphemy
man my head hurts...
ZedEx Crew Member #61988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc. blown turbo, under construction.. gt35 coming. |
Re: z blasphemy
wow, that is amazing, i would of never been able to do that.
Re: z blasphemy
sweet, thanks for the info im just going to rebuild the z, but as for the maxima i think the aftermarket turbo will be easiest.... although i dont necessarily enjoy easy.
thanks again, its good to know that if i have trouble with the rebuild of my 1990 i will have an buttload of really smart z lovers out here to help.
Re: z blasphemy
the max is manual and the 300 is auto.
