Go Back   Automotive Forums Car Chat > MG > MGB
Old 08-12-2005, 10:13 PM
Bodack Bodack is offline
Send a message via AIM to Bodack
Clutch Hydraulic Problem
I have a 1979 MGB and I'm having problems with the clutch. When I press it once, the clutch doesn't disengage and doesn't have much resistance. But when I pump it a few times it has more resistance and the clutch will disengage. Also if I pump the brakes a few times it will fix it also. It's been bled by my semi-knowledgable step-father, and that made a very small change. Has anybody had this problem? If so, how'd you fix it?
Old 08-12-2005, 10:19 PM
KimMG KimMG is offline
AF - Advisor
Re: Clutch Hydraulic Problem
Sounds like the internal seals in the clutch master cylinder and the brake master cylinder are shot. Rebuilding or replacing are the only options.
Old 01-11-2008, 09:36 AM
Bluetick Bluetick is offline
Agree. Suggest rebuilding the master cylinder first. BE SURE TO BLEED IT COMPLETELY & CORRECTLY! If you still have problems then you'll need to go to the hydraulic slave cylinder beside the transmission and rebuild that, too. Again, bleed it completely.
Good luck.
Bluetick.
Old 01-11-2008, 12:37 PM
AF - Advisor
Bluetick-
You have responded to a post that is more than three years old.
