Go Back   Automotive Forums Car Chat > Toyota > Avalon/Pronard
Old 08-12-2005, 09:56 PM
speedysportcar speedysportcar is offline
Question trans problem?? cv problems??nope mybe egr
on my 97 avalon at hiway speeds(45-65mph) the car hesatates/surges. It does this w/wo o.d. the rpms do not bounce. also there is a viberation at these speeds. put new tires on still have vibs. every once in a while it surges when starting out from a stop(1-5mph). could this be cv or bearings going bad
Old 08-23-2005, 08:08 PM
Joe W Joe W is offline
Re: trans problem?? cv problems??
Have the wheels been aligned lately?
Old 08-25-2005, 08:56 PM
no they have not. but i did clean out the throttle body. it needed it bad. the hesatation/surge stopped at hiway speed. but still does it at 1-5 mph. mostly when the car is warm. still stumped but searching. ty
Old 08-25-2005, 11:00 PM
Could be more than one problem. the hesitation could be anything from a borderline O2 sensor to bad plugs, the vibration could be alignment, assuming the balancing was done on the new tires. It is unlikely that the surging 1-5 mph is cv or bearing related, but from the description, sounds performance related. Hope this helps. The throttle body cleaning helps with a sticking pedal.
Old 08-29-2005, 09:45 PM
Re: Re: trans problem?? cv problems??
thanks for the reply Joe. while I was looking at write ups I came acrossed one from mb_. On his 98 Avalon he had the same problem on the hesitation, as I do. He changed the EGR valve and EGR vac. valve. And it solved his problem. When I get to Toyota dealer to get my parts and put them on I'll let you know if it worked for me. I'll also get an alignment. Once again thanks for answering my post. Patrick
