Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 08-12-2005, 08:38 PM
bmc4057 bmc4057 is offline
Intake Manifold '97 5.7L Chevy Pickup
My truck overheated today. The engine runs fine but water is pouring out from between the intake and the head on the left bank at the front of the engine under the A/C compressor.
Any easy fixes?
Old 08-13-2005, 01:57 AM
Jim Adams Jim Adams is offline
First thing to check is the oil,,cause as easy as it is for it to be puoring out onto the ground it can leak ino the oil Gallet,,so be sure to check that oil isnt muddy orantifreeze on bottum of dipsticck,,,try to put a wrench on it and tighten the bolts a little,,if this doesnt work then you have to change the intake runner gaskets,,,
Old 08-14-2005, 12:24 PM
Re: Intake Manifold '97 5.7L Chevy Pickup
Oil is okay...guess I have change a gasket.
I'm just hoping that's all it is.
Thanks
Old 08-16-2005, 06:46 AM
drdd's Avatar
drdd drdd is offline
Re: Re: Intake Manifold '97 5.7L Chevy Pickup
change your lower intake gasket. change oil and filter when finished.
Thanks
Old 08-16-2005, 08:25 AM
tom3 tom3 is offline
Getting to be one of the most common failures on a GM V-type engine these days. Pretty poor design with the vertical bolting to a very low torque. Might read up on ignition timing before pulling the distributor, maybe not the usual deal of the old days, not sure on the 97.
