Old 08-12-2005, 07:07 PM
s10_blzer s10_blzer is offline
Bah...New Problem...Radiator Fluid comming up under passanger floormat
I'm having what I want to say is radiatior fluid comming up from under my passanger side floormat.....and was wondering what could cause this problem. Seems to be never ending problems with my blazer but I'm gonna keep on truckin' hah well any possible diagnoisis and solutions would be greatly apperciated. Thank you!
Old 08-12-2005, 07:26 PM
blazee's Avatar
blazee blazee is offline
Problem?
Re: Bah...New Problem...Radiator Fluid comming up under passanger floormat
Sounds like your heater core is leaking. You will have to dismantle the dash to replace it. It isn't a very fun job. Under the hood you will see two hoses entering the firewall. You can connect these two hose together to bypass the heater, so that you can drive it until you can replace the core. Do a search for "heater core" to get more info
Old 08-12-2005, 07:53 PM
JC327's Avatar
JC327 JC327 is offline
Yep, leaking heater core. Whew, have fun with that one...
Old 08-12-2005, 08:09 PM
s10blazerman4x4's Avatar
s10blazerman4x4 s10blazerman4x4 is offline
Send a message via AIM to s10blazerman4x4
http://www.sytyarchives.com/howto/vi...imate_controls
If you follow that link it will still be fun but that helps alot because it gives you general idea what fun it is
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3
Old 08-13-2005, 12:11 AM
friend trying to tell me its tranny fluid...any chance to this?
Old 08-13-2005, 01:07 AM
blazee's Avatar
Problem?
Not unless you spilled a quart of tranny fluid in the floor.
Old 08-13-2005, 02:14 AM
JC327's Avatar
Yeah, if you've got tranny fluid leaking onto your floorboard, you need to sell that thing now, it's REALLY messed up...
Old 08-13-2005, 05:53 AM
Take your face and put it against the carpet
Old 08-13-2005, 08:55 AM
slacker_53's Avatar
slacker_53 slacker_53 is offline
Stick your finger in it and taste it, antifreeze, or excuse me, radiator fliud, will taste sweet.
Third vote for the heater core.............or is that the fourth??
When I die, I want to die peacefully in my sleep, just like my grandfather................not yelling and screaming like the other people in his car!
http://www.geocities.com/tbuckit1/index.html
Old 08-13-2005, 01:43 PM
is there any possible way that it could be tranny fluid though?
Old 08-13-2005, 01:48 PM
uhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
nooooooo.
Old 08-16-2005, 10:02 PM
rstyrlz rstyrlz is offline
nope. ( have your friend change your turn signal fliud for ya while your fighting with your leaky heater core)
Old 08-17-2005, 01:52 AM
wolfox's Avatar
wolfox wolfox is offline
Send a message via Yahoo to wolfox
Okay, okay guys. Please, the fellow asked a legit question - and admittedly, it's easy to confuse Dexcool with ATF on a colored, carpeted floor unless you can directly compare the two fluids when you're new to the truck and general repair. To s10_blzer:
The likelihood of finding tranny fluid on your floorboards is exceedingly rare unless something happened to put it there, like a bottle with a loose cap in the passenger floorboard while on the way back from the auto parts store. ATF smells like a light petroleum oil, because, well, it is! Dexcool will have a sticky, acrid odor especially when warm and a leaking heater core will also fog the windshield glass or give you a burst of very humid air with visible steam when you first turn on your climate controls. (Engine already hot) The chances of ATF leaking into the passenger compartment could only possibly happen if conditions were just-so, like in a rollover, that it's *almost* laughable. Chances are your heater core's got a pinhole and your radiator and overflow tank are also slowly loosing fluid. Check under the radiator cap when the engine's dead cold in the morning after sitting overnight. Also look in your overflow tank on the passenger side wheel well. If the tank's low or dry, and you cannot see coolant all the way up to the neck under the radiator cap, it's Dexcool on your floor boards and a lengthy do-it-yourself, but not entirely impossible to repair problem with the heater core. If you cannot trust yourself to change the plugs in the truck, it would be best to seek enlightnened or professional help to get the job done.
Wow, I can't believe I got through that without one funny comment...but you have to admit...*snicker* ATF on the floorboards? That's almost as good as the GM recall for faulty epoxy bonds on door hinges. (*Patiently awaits for the randomly thrown wrench to bean him on the noggin*)
Old 08-17-2005, 08:49 AM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
Definitely your heater core. Sorry bro, good luck. Amazing how often those hard to get at little buggers go bad and cause so many issues!
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
