Old 08-12-2005, 06:47 PM
Vtec95Civic Vtec95Civic is offline
O2 sensor question.. NEED QUICK RESPONSE
OK.. sorry for the multiple posts on one subject but I need a FAST answer to this.
So I'm installing the new 4-2-1 header I just got, and it moves the O2 sensor down near the cat. The header came with a little extension on the wire but I'm not sure how to run it back up to the original plug.
Do I go all the way back to the engine with the extension? Or just to where it plugged originally? The original goes back into a LOT of insulated wires and I don't want to tear it all apart.
I just don't know how to run the wire without having it touch anything hot. Should I go up around the front of the block or straight up from the secondary pipe?
Old 08-12-2005, 08:14 PM
Privatebigandrew's Avatar
Privatebigandrew Privatebigandrew is offline
Send a message via AIM to Privatebigandrew Send a message via Yahoo to Privatebigandrew
Re: O2 sensor question.. NEED QUICK RESPONSE
do it the way that provides the least amount of excess wire. Sounds like you are freaking out It's just a car, don't stress it to much. If something on it breaks, it can be fixed. always remember that, and your jobs will go alot smoother.
94' Del Sol VTEC (B16A3) SOLD.
Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles.
Old 08-12-2005, 08:36 PM
Too much has gone wrong already.
Didn't have a 1/2 inch drive for the O2 socket, so no idea how tight that is. Currently need to find a 1/2" extension for the torque wrench so I can tighten the nuts to the block.. as you can probably tell we don't have a huge assortment of tools.
Old 08-12-2005, 11:51 PM
Ok.. well now am I fucking allowed to flip out. Fucking torque wrench didn't stop at fucking 23 lb-ft, resulting in the nice break of one of the god damn bolts that come out of the block. So now I have to have it towed to get fixed at Honda while meanwhile I have no fucking way to get to work.
Old 08-13-2005, 12:53 AM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
If you're talking about one of the ones that holds the header on; I'd personally just attach it with the other bolts and drive it to get the bolt in the morning, and put it in right before work. Probably not a good idea, but I'd assume the other bolts would hold fine for a little while.
Old 08-13-2005, 03:07 AM
fasthatchb18c1 fasthatchb18c1 is offline
Drill a small hole in the bolt then put a screw in there with some J/B weld on the thread. Let it dry and you might be able to get it out yourself. I just did this 2 days ago and it worked.
Old 08-13-2005, 03:18 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
you must have put alot of pressure on it, because, i actually use those threads to hold the engine up with my engine lift.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 08-13-2005, 08:21 AM
I was tightening the nut onto the bolt and apparantly the torque wrench didn't stop at 23 lb-ft because all of a sudden crack.
Now I'm waiting for Honda to get back to me. We were almost finished too.. just had to tighten up everything.
Old 08-13-2005, 06:20 PM
actually, those bolts are extremely weak in an aged engine. When i was putting my header on @ 112,000 minles, three of them broke with hardly any force at all on a 3/8's ratchet. I had just started to tighten them up and they broke. I even am still missing the far left one on the bottom, and have been driving like that for 30,000 miles with no leaks. I have learned to replace all of the bolts from now on when installing a header. I think i may finally tackle that bolt in the head sometime soon, as i am tired of it missing. You should be able to get it out with a 90 degree angle drill and an extractor set. They usualy come out by hand once you break them loose.
Old 08-13-2005, 08:08 PM
Considering that it took us the better part of like 5 hours to even do the header itself, I don't think I'm mechanically inclined enough to fix it.
