Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 08-12-2005, 04:29 PM
StoZzy_RoX StoZzy_RoX is offline
Serious Issue, Need Info Asap
OK. I'm sellin my CRX. it's an 88 DX, original motor, just got the body kit n some cosmetic upgrades. But that car sat for 2 months while i was workin on my other CRX and now the red beauty is givin my problems. It starts up fine and everything, and in reverse it's fine. but any forward gears and it wants to bog down and die. The guy is suppose to come out and buy the car Monday, so time is a factor like whoa. Any help or suggestions would be AWESOME. Thanks guys.
Also I need the spec on the type of bolt used for the wheel. The bolts that hold the wheel on and the rotor slides onto. the main ones on the spindel. I gotta slip a new one in but don't have the old one to compare too. Should I nab that at a autozone of go to the factory and snatch one from them?
Old 08-14-2005, 09:44 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Re: Serious Issue, Need Info Asap
So you're saying your car bogs then. Well first see if its throwing any codes on your ecu. IF anything it sounds like you need a tune up. About the bolt...are you talkin about the axle nut or the wheel stud? You can buy them at Honda. Thats the only place I know that they'll sell the axle nut seperately otherwise you will have to buy the whole axle just for that one nut. I'd go with honda for the wheel stud also. Hope that helps.
