Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 08-12-2005, 03:08 PM
domina domina is offline
Question 2000 Jetta - A/C Low Pressure Valve
Can someone tell me the location of the A/C low pressure valve for a 2000 Jetta as I'm trying to add freon to the system? Appreciate any help on this.
Old 08-13-2005, 08:46 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
uh... there is no low pressure valve.
You can add freon to the system at the schrader valve. high side by the radiator low side by the h-block by the firewall i believe.
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 08-13-2005, 11:38 PM
Smile Re: 2000 Jetta - A/C Low Pressure Valve
I'll give that a shot. Thanks for the info!
Old 08-14-2005, 09:16 PM
Thumbs up Re: Re: 2000 Jetta - A/C Low Pressure Valve
I ended up filling it from valve near the radiator as you noted and it worked! Thanks for the info!
