View Poll Results: what should i do
replace with rebuilt engine 3 20.00%
tear engine apart to searchfor knock 3 20.00%
blow it up with a stick of dynamite 9 60.00%
Voters: 15. You may not vote on this poll
Old 08-12-2005, 12:10 PM
dnmir54 dnmir54 is offline
Question engine noise
have a 2.4 dual overhead cam engine that has developed an engineknock or rapping sound have gotten opinions on what its is from timing chain slapping , rod knock, bad lifter ,
i think it may be a bad lifter ,how do i go about finding what is really making the noise engine has 84,956 miles on it
Old 08-19-2005, 12:06 AM
roggin323 roggin323 is offline
Re: engine noise
unfortanely ur gonna have to get to the root of it. which usually mean tear it down and hope u find it. it could be one of everything you metioned or it could be a valve that needs to be tightened, but if i had to guess id say bad lifter.
Old 08-29-2005, 12:07 AM
Re: Re: engine noise
[quote=roggin323]unfortanely ur gonna have to get to the root of it. which usually mean tear it down and hope u find it. it could be one of everything you metioned or it could be a valve that needs to be tightened, but if i had to guess id say bad lifter.[/Q
thanks for the reply i almost have the engine apart as soon as i crack loose the crankshaft bolt iwill be able to evalueate the timing chain and then i will remove cam carriers and the head.-
Old 12-22-2006, 06:20 PM
PulledOverAgain PulledOverAgain is offline
Re: engine noise
I had a friend with the same problem. He decided to just drive it til it dies.
It never died.
