Old 08-12-2005, 08:11 AM
Nigel215's Avatar
Nigel215 Nigel215 is offline
is this safe?
just a quick question..ive been running 89 octane gas for about a year now, but the price of gas is really killing me. is it safe for me to just go back to 87 again? I dont have any custom tune or anything, but i was just curious if this would cause a knock or something, or just not be good for the engin? thanks
2000 Silverado LS 4.8, K&N FIPK, Gibson Extreme Dual Exhaust, Line-X Bedliner, Black Speed Grille, Viper Alarm System, Custom Audio system.... (need to update my pic)
Old 08-12-2005, 08:49 AM
Seabornman Seabornman is offline
I've never run anything but 87, and it does just fine. I have an '01 4x4 with 4.8 engine. I agree, there is a big price jump to 89 octane.
Old 08-12-2005, 09:14 AM
BowtieX3 BowtieX3 is offline
Your Owner's Manual has factory suggested fuel recommendations. It will say what you should run...however, keep this in mind...the higher the octane, the cleaner the fuel, meaning the more complete burn you'll acheive, meaning the better mpg you'll get. You'll also have less carbon running through your engine, less potential for future problems. Uncle works for Exxon...take it for what it's worth.
I know prices at the pump are horrendous (I have to run 93...6.0 HO). If you do run 87...twice a year I'd run a cleaner like the Chevron concentrate through a tank...my two cents worth!
Old 08-12-2005, 09:27 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
Re: is this safe?
I've run 93 since the day I bought my truck almost 4 years ago. I'm swapping back to 87 next week when my new tune is here. I've got to, the 93 here is almost 2.70/gal
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 08-12-2005, 11:14 AM
jers99z jers99z is offline
Send a message via AIM to jers99z Send a message via MSN to jers99z Send a message via Yahoo to jers99z
i would say if you dont have a chip or tune done running 87 should be just fine, ive been thinking about taking my chip out just to run 87, gas prices are ridiculous in hawaii and driving over the mountains aint exactly fuel efficient
Old 08-12-2005, 11:17 AM
White Lightening's Avatar
White Lightening White Lightening is offline
Is it worth it?
I did a calculation as follows:
If a truck owner drives 15,000 miles per year averaging only 18 miles per gallon using 92 octane and the difference in gas price for 92/93 to $2.70 per gallon versus $2.50 for 87 octane fuel. Lets also use the fact that the average (MPG) would go from 18 (with premium) to 17 (using regular). The actual net difference in cost ====== $45.00 a year.
As a result - it seems it would not pay to switch to lower octane. In my area - the difference in price from premium to regular is only 12 cents a gallon where I get gas. However I had used 20 cents in the calculation - to even try harder to favor regular. Even under those conditions - $45.00 just isn't worth the difference in my opinion - I'll stick with premium till it cost justifies a switch.
. . .>>>>> . .White Lightening . .<<<<<
More pictures???
Link below shows them & a list of features and options on this 2wd SS
V.H.O.
http://files.automotiveforums.com/ga...ite+Lightening
Old 08-12-2005, 11:33 AM
Nigel215's Avatar
Re: is this safe?
Yea, that is one of the reason i started running 89 in the first place, for everything to run a little cleaner.
Old 08-12-2005, 11:36 AM
sportin83 sportin83 is offline
Send a message via AIM to sportin83 Send a message via Yahoo to sportin83
i try to run 89 most of the time, but i get 87 once in a while. sometimes if i have a few extra bucks i though in 92 or 93. the way i look at it is if you run 87 then once and a while i have been told you need to run a fuel cleaner throught the system, but that is like 4 buck s a bottle so what are you saving by going cheaper on gas?? my 2 cents
2002 CHEVY SILVERADO
more pics at http://www.cardomain.com/ride/2228127
Old 08-12-2005, 01:58 PM
twomorestrokes's Avatar
twomorestrokes twomorestrokes is offline
87 octane is fine with your stock truck. That's all I use in my 6.0. and I rag it hard. It is a waste of money to use higher octane than you need to in a stock vehicle. Although it won't hurt anything, you are not doing your engine any special favors by spending more $$ on slower burning fuel. Higher octane is only needed to prevent preignition when the compression or timing has been altered, or if it is a special factory performance package.
As far as cleaner burning goes, the big oil compaies have gotten you believing that. If anything, using higher octane than you need to has the possibility of being less clean. All higher octane does for you is make the mixture harder to ignite in your cylinders. If you are having detonation problems then higher octane is for you. If it runs good on 87, then it is actually burning faster and cleaner with lower octane.
Old 08-12-2005, 03:12 PM
Ape0r Ape0r is offline
Send a message via AIM to Ape0r
Re: is this safe?
89/93 are not any cleaner at all than 87, except with brands such as Shell that offer additional advertised cleaning agents. The octane number relates to resistence to combustion, you will achieve a more complete burn with the CORRECT octane rating. If you have a 93 tune, use 93. If you have no tune, use 87.
'04 Silverado 1500 4x4 5.3L 3.73 G80
Old 08-12-2005, 04:29 PM
Re: Re: is this safe?
Actually Ape0r, thats not quite correct. Many GM products benefit from using premium gas. Octane numbers - as you mentioned - do relate to resistance to combustion. 93 has more resistance than does 87. But its compression ratios when used in conjunction with octane numbers that give you the right choices. I have a 10:1 ratio compression - and using premium is needed. The result of using premium with higher compression levels - will give better mileage and better performance. Similarly - using premium gas with a low compression engine - gives you unburned hydro carbons, poorer mileage, and a loss of power. Most bigger block V8's improve with premium. Most V6 engines work better with 87 octane (because they don't have high compression).
More pictures???
V.H.O.
Old 08-12-2005, 04:37 PM
NoRiceHere01 NoRiceHere01 is offline
Re: is this safe?
thank u for knowing wut ur talking about haha. im tired of explaining to people wut octane ratings mean. these things run fine on 87 and ur engines not gonna notice the switch. running a certain fuel in ur engine does not condition it one way or another. my 76 ran on 87 like it was supposed to until i advanced the timing to a suitable level and then put an advance curve kit in the distributor. i thought i killed something cuz of the noise it made until i took my dad for a ride to show him and he was like "u need better gas idiot u know wut u just did to the timing?" unless u got a tune or raised the compression ur better off with 87. if not for the price, as white lightning pointed out, then for emissions. if u use a fuel that does not burn completely then ur actually increasing bad emissions. not that i care. emissions regs suck. now that i think about it, if i read the advice i just gave, i would be no closer to a desicion then before i read it. please ignore me, its been a long day.
Old 08-12-2005, 04:50 PM
Slowprocess's Avatar
Slowprocess Slowprocess is offline
Send a message via Yahoo to Slowprocess
Running 28 degrees of timing and nitrous.....I think I'll stick with 93.
Daily Driver- 00 Camaro SS A4 1/4- 12.30@118mph 2.14-60ft on street tires
Weekend Warrior-99 Silverado "Dirty" 1/4-11.63@118mph 1.8-60ft
Old 08-12-2005, 05:53 PM
broughy84's Avatar
broughy84 broughy84 is offline
Re: is this safe?
Wanna here something sad.......
At BP here gas is $2.22 for 87, 2.32 for 89, and 2.42 for 93.
At Casey's its $2.27 for 87, and $2.20 for 90, yes that is right, it is not a type, premium is cheaper. The Reason being, they have a larger tank tank BP (as they are across the highway) and they can buy in huge quantity... Low price = high demand
At D&B 87 is 2.52 and 89 is 2.85 this station is only 10 blocks from the others. What a difference!
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Old 08-12-2005, 06:05 PM
jeverett's Avatar
Re: is this safe?
I'm broke, im going back to 87
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
