Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 08-12-2005, 03:58 AM
illsmokeu illsmokeu is offline
she's smokin
Hey guys n gals sup! i just bought a 92 prelude si and she runs like a biatch on fire, but there's a slight problem. Sometimes when i strat the engine she throws out white smoke, at first i thought it was the oil but everything seems to be perfect, she doesn't hesitate while drivin either and iv'e heard white smoke is good but black is bad, so i'm guessin it's something small, i haven't checked the spark plugs - u think it could be that?? i'll appreciate any kinda info. Thanx
Old 08-25-2005, 09:27 AM
B20a5=vtec B20a5=vtec is offline
Send a message via AIM to B20a5=vtec
Exclamation
Okay I have an 88 lude and its also throwin out white smoke.........white smoke isn't always good..........wat u want to do is make sure u aren't having any drop in your oil level by checking it from time to time............if it starts smokin after the car has been driven or warmed up then it might be your piston rings............if it smokes when u are warming up the car then it stops, then just flush the motor with motor flush and chang the oil...........if u don't feel like going into to much trouble, get a can of "Seafoam" at any major autoparts store..........3 easy steps, pour, run, rev.....................hit me up wit any more questions...........................
Old 08-26-2005, 01:10 AM
93prelude_si 93prelude_si is offline
i have a friend with a car that used to put out some white smoke when he started it. it was alright at other times, but it only smoked when he started it. he ended up having to get his heads rebuilt. not sure if this helps, but its a possibility.
Old 08-26-2005, 03:45 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
Head gasket, maybe.
Old 08-30-2005, 09:04 PM
gerhard gerhard is offline
First off... Don't drive the car is it's at all possible.
The best thing for determining the problem is to change the oil and send a sample out to a lab.
The place I use is Blackstone Labs.
http://www.blackstone-labs.com/free_test_kit.html
They will send you a sample container and then you send it back. They will then send you an oil report and tell you if there is any antifreeze, even very small amounts, in your oil.
The engine WILL be destroyed if you drive it with anti-freeze getting into the oil.
Old 09-01-2005, 03:12 PM
Re: she's smokin
thanx for the help guys , it was just some dirty oil!
Old 09-01-2005, 03:53 PM
Re: Re: she's smokin
Huh?
