Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 08-12-2005, 02:35 AM
Goombaw Goombaw is offline
Send a message via AIM to Goombaw
Dodge Dakota P0455
about 3 days after i bought my dakota the check engine light came on, i did some web surfing and found that the error code is P0455 evap system leak ( http://www.allpar.com/fix/computer-codes.html ) but i cant find any thing on how to trubleshoot it. any ideas?
Old 08-12-2005, 10:53 AM
timbo_lan71 timbo_lan71 is offline
Re: Dodge Dakota P0455
P0455 is a "large leak detected" in the evap system,you should take your gas cap off and tap it on a workbench or another hard surface,if rust comes out then the check valve or vent is probably stuck in the cap,sometimes just the tapping will free it up,or you can take the cap apart from the underside and free everything up inside,or you could just replace it,but that takes all of the fun out of it..........
Old 08-16-2005, 07:22 PM
I tryed the gas cap taping the gas cap, no rust. Still my engine light is on so I bought a new gas cap. no results. I disconected the battery to try and get the light to reset that didnt work eather. Is there any thing else I can check?
Old 08-16-2005, 10:19 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
P0455 has to do with the NVLD pump circuit of the EVAP system. Chances are you have a small pinhole leak in the line(s). It's not a serious driveability code, it'll just light up check engine light b/c the pressure is not building up in the system properly. You can go to a shop and have them smoke test your system to see if they can locate the leak.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 08-31-2005, 11:54 PM
I ended up taking it to the dealership it took the guy about 30 sec to find the leak there is a charcal filter ,on the under side of the truck just behind the driver seat, that has a vacume hose that has been known to crack. this was my problem.
thanks for your help
