Old 08-11-2005, 11:35 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
1999 Chevy Silverado Z71 Off Road (Lifted)
Wow, I havent built a model in awhile, huh? Oh well, heres my comeback... its based off the Revell 1999 Silverado CK 2WD Extended cab... but its going to be built into a modified Z71 equipped truck.
I remember seeing someone else build a Z71 Silverado. Does anyone know where I can get some Z71 Decals?
Also, what color do you think this would look good in? I'm thinking a dark metallic green?
Heres some mockup pics..
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 08-11-2005, 11:49 PM
spitfire143 spitfire143 is offline
Re: 1999 Chevy Silverado Z71 Off Road (Lifted)
looks good so far! Dark green would be nice, but a gunmetal IMO would look great
Brakeneck.com
Old 08-12-2005, 09:36 AM
tonioseven's Avatar
Dark Metallic green with a 2-tone tan interior!
Old 08-12-2005, 03:31 PM
ToyTundra's Avatar
ToyTundra ToyTundra is offline
I was just debating whether or not to pick up that very kit.
Old 08-12-2005, 03:35 PM
Jeep_Rubicon's Avatar
Jeep_Rubicon Jeep_Rubicon is offline
Looks great, nice lift and wheels.
Old 08-12-2005, 05:06 PM
eph2 eph2 is offline
Send a message via MSN to eph2
Is gonna be a cool car!!!
Old 08-12-2005, 05:33 PM
blubaja's Avatar
blubaja blubaja is offline
Green? Ugh...I hate dark metallic green. But you will make it look nice I am sure. Is it going to be 4WD at least? I remember there was a West Coast Customs lifted RWD tahoe or something. Oh, and dubs...WTF people!!!! Learn how to make something not look like a POS! UGH!!! Um...
What did you use for the suspension parts?
Is this getting a rollbar and the necessary off-roading equipment? Good luck the with rest of this:-D
Old 08-12-2005, 09:24 PM
Jaymes's Avatar
Jaymes Jaymes is offline
I think navy blue would look best with this car
looking forward to more
Old 08-12-2005, 10:40 PM
Yes. it is a 4x4. Not a 2wd. (Z71's only came in 4x4 anyways)
For suspension parts? Well, I custom built the IFS Crade using block some tubing.
Heres the skeleton of the cradle:
After the cradle was assembled, I used the kit supplied upper and lower control arms, and spindles, and used mostly recycled/kitbashed parts.
To extend the spindles, I put the rest of the shock tube from the PL GTO kit. I used a front differential housing from a Toyota Hilux, and used the PL GTO Half shafts. I used the stock tie-rod, just to be sure the suspension is the right width. Then i also used coil springs from the Revell Civic (Both front and rear, I trimmed them, and put two together to make one long one)
As for the rear end, I used the stock GM 12 Bolt, and rearched the leaf springs. I also added lift blocks, and made a new rear leaf hangers/shackles.
Old 08-12-2005, 11:08 PM
Here are a few better pics.. Now I'll finally have a lifted truck from each of the big 3.
("Big Red" F-250, and "The Tow Truck" Dodge VTS) You can see them, if you search..
Heres the rear end:
Front:
Front bottom:
Old 08-12-2005, 11:13 PM
white97ex's Avatar
white97ex white97ex is offline
Send a message via AIM to white97ex Send a message via Yahoo to white97ex
nice work on that cradle
My name is Russell, feel free to use it.
I'd rather be hated for Who I Am than be loved for Who I Am Not
Old 08-13-2005, 05:27 AM
SupaMan89T's Avatar
SupaMan89T SupaMan89T is offline
Send a message via AIM to SupaMan89T Send a message via MSN to SupaMan89T Send a message via Yahoo to SupaMan89T
great work so far!
Project Lexus Revive
Old 08-13-2005, 01:05 PM
Heres some updates. I finally got the tires, wheels, and brakes mounted.
I realized the rear end sits a little low, compared to the front, so I'll have to level that out...
Old 08-15-2005, 12:06 AM
351Cougar's Avatar
351Cougar 351Cougar is offline
leave it as is
my name is Justin feel free to use it
69 Cougar 351W fmx 3.00s 17x8 06 bullits... sold
92 Camaro RS 305 tbi T-5 purple haze metallic (92 color only 1 of 8,556) - custom ram air, lowered
88 AE92 4afe powered sedan.. got it for $250
Old 08-15-2005, 06:33 AM
SupaMan89T's Avatar
looks awesome!
