Go Back   Automotive Forums Car Chat > Toyota > Celica
Old 08-11-2005, 10:04 PM
CelicaGTS21 CelicaGTS21 is offline
2002 Celica GTS
Hey, i just got a 2002 Celica GTS with about 23K on it....... What should be my first modification??
Old 08-11-2005, 11:03 PM
Vip09 Vip09 is offline
Send a message via AIM to Vip09
Re: 2002 Celica GTS
A 00-01 ECU and knock sensor. Having a 7800rpm rev limiter sucks compared to 8400rpms in 2000-01.
Best GT-S STOCK times: 1/4: 14.788 @ 94.98mph 1/8: 9.640 @ 75.87mph
Best Alltrac times: 1/4: 13.3 @ 102mph (older setup) 1/8th: 7.8 @ 83mph (old setup)
Old 08-14-2005, 10:03 AM
Re: Re: 2002 Celica GTS
How do i get ahold of an 00-01 ECU and knock sensor?
Old 08-14-2005, 12:05 PM
jaybratt jaybratt is offline
Send a message via AIM to jaybratt Send a message via MSN to jaybratt
Re: 2002 Celica GTS
The Ecu could probably be found on ebay, I don't know what a knock sensor is, so I can't really help you there. Sorry
My Trac
Old 08-14-2005, 11:59 PM
Re: 2002 Celica GTS
Thanks guys I appreciate it
Old 08-15-2005, 10:31 PM
91 Celica St 91 Celica St is offline
AF - Advisor
Re: 2002 Celica GTS
a knocok sensor is pretty much what it says, detects knocking, it makes it so you dont getdentonation and stuff, it will tell the ecu to lean out and ritchen the a/f ratio to make dentionation not happen....it also makes it so you can run 87 octane instead of 91 but you will have a slight power loss
Old 08-16-2005, 01:28 AM
You have to get a knock sensor, because in 2002 they changed the knock sensor to a different wire configuration (I think a two wire) and the pre 02 knock sensor is a single wire.
