Old 08-11-2005, 09:29 PM
Jim Adams Jim Adams is offline
Frame flexing issues!!
I have a 1977 T.A. with a 1970 Ram Air III 60 over TRW,s ported and polished heads a lunati cam ,Torker intake 750 double pumper with 1-5/8s tube headers ,hi output accell distrubutor,,2,1/2 inch stainless exhaust with flowmasters a steel crank ,steel rods she,s all balanced with a 400 turbo reverse valve body w/3800 stall conveter and a 12 bolt posi with 4.10 gears. She has T-tops but I put in a 6 point cage and then added frame connectors ,,I thought I had the problem whoopped but then the other night I was In the Amish country no one around and wanted to put her to the test I rolled off and when she hooked up and I stabbed 2nd gear she blew the T-top out on the passenger side ,,It has done this before,,that is when I started with the 6 point and then I put 1/8 inch steel plating in the front lower quarters and up the sill plates ,,still did it then I went with frame connectors and she still does it,,what else can I do to stop it from blowing t-tops . Any help would be appreciated ,Ive been trying to correct this problem for about a year now been threw 6 tops lol,,I would hate to have to cut the roof off and put a full roof on her she is to nice T-Topped.
Old 08-11-2005, 11:22 PM
CDJr CDJr is offline
Re: Frame flexing issues!!
You may try asking that question at the PY forums, Im sure someone knows a way. http://216.178.81.108/forums/ Are your SFC's welded in or just bolted?
Old 08-12-2005, 12:18 AM
the subrame connectors are welded in!
Old 08-12-2005, 01:40 AM
Well, that shoots down my theory lol. Did you try the PY forums?
Old 08-12-2005, 08:21 AM
MrPbody MrPbody is offline
AF -Advisor
Make it an 8 or 10-point, like you would in a convertible.
Where did you EVER find a steel crank for the 400? How much did you pay? Zero factory 400 cranks were steel... (except the few Ram AIr V pieces that sneaked out the back door, as Ram Air IV "Super Duty").
Old 08-12-2005, 08:04 PM
I had thought about going with a 6 or 10 cage but I still take the kids out for country rides and that would Kinda make it uncomfortable in the back if I went with a 10 and cross barred it.I guess this is my only option?? I even drilled and spot welded the floor to the sub frame connectors I welded in to stiffin her up there.
Old 08-13-2005, 04:25 AM
volkerc's Avatar
volkerc volkerc is offline
Nice car, and thanks for the warning, I know I will test mine,when its done, with my t-tops off...
