engine dies and won't restart
The car is a '94 1.0 liter with auto transmission. The engine dies
without warning and will not restart 'til it has "rested" for almost an hour. The days have been very hot and I suspect a heat related ignition problem. All new spark system wires. Could it be a defective coil? Starter cranks ok. Any ideas? Thanks |
Re: engine dies and won't restart
i would suspect ignition module. next time it dies pull coil wire out of cap and put it about 1/4" from metal and have someone crank it while you see if there is any spark
Re: Re: engine dies and won't restart
then none thereafter. I replaced the coil/igniter and pickup module with no success! This car has the "upgraded emissions" package or electronic spark control distributor. Fuel pump?? It runs for several moments if I "prime" the carb. Thanks for any info. |
Re: Re: Re: engine dies and won't restart
[quote=robogo]several days later.................same problem. Spark for a moment and
then none thereafter. I replaced the coil/igniter and pickup module with no success! This car has the "upgraded emissions" package or electronic spark control distributor. Fuel pump?? It runs for several moments if I "prime" the carb. Thanks for any info.[/QUOj Just found prices on a replacement fuel pump $113 - $310.......... outrageous, I've bought the wrong car !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! |
Re: Re: Re: Re: engine dies and won't restart
[quote=robogo]
BTW where did you find a fuel pump for $113? |
Re: Re: Re: Re: Re: engine dies and won't restart
BTW..........Google O'Reilly auto parts. I also found a salvaged pump for $50.00 |
8 days later......... as it turns out the major problem was
a broken/defective electrical connector on the fuel pump itself (I blame it on the incompetent tinkerer that last owned the car)........thanks Crvett69 Darterburn.........I gave you bad info last time, search for Rockauto |
