Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-11-2005, 07:49 PM
ffwv ffwv is offline
98 Eclipse door locks backward
My daughters 98 Eclipse unlocks its doors when you put it in drive. It locks the doors when you put it in park and turn off the ignition. This seems backwards to me. Any ideas where to start looking ?
Old 08-11-2005, 10:37 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: 98 Eclipse door locks backward
lol definately backwards. it sounds like a short somewhere. do the locks work normally with the switches?
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 08-11-2005, 10:53 PM
clipsekid99's Avatar
clipsekid99 clipsekid99 is offline
Send a message via AIM to clipsekid99 Send a message via MSN to clipsekid99
Does the car have the stock security system, an aftermarket security system, or no system at all?
2006 Wicked White Evo IX GSR
323 awhp / 311 tq. (Dynojet)
http://www.projectevoix.com
http://www.4WStuning.com
99 RS < 98 GSX < 06 EVO
Old 08-12-2005, 04:48 AM
Yes, the locks work fine manually and yes it does have the factory security system- but that is unhooked. Or at least it hasn't worked since she has had the car. That's about 2 months. Thanks!!
Old 08-13-2005, 04:46 AM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
you can check by locking the door with the key. does the security light come on?
someone may have unhooked the system to put in an aftermarket system, then taken it out, and reversed the wires? not sure. i would take it to a dealer and se if you can get a favor. you never know...
Old 08-13-2005, 10:04 AM
Re: Re: 98 Eclipse door locks backward
The security light stays on all the time. I suppose this would indicate that the problem is in the security system wouldn't it ?
Old 08-13-2005, 12:29 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
The security light should only be on for the first 15 seconds after the car is locked. Then the light goes away, but the car is still secured. If the light is constantly on, it's trying to tell you that it's not working properly. I bet the previous owner thought he was a genius and tried to install a better alarm, got half way through realizing he was a dumbass, and left everything fucked up. This one might cost you a nice chunk of money to fix man.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
