Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 08-11-2005, 08:36 PM
E-Mang E-Mang is offline
Send a message via AIM to E-Mang
Engine Question
What's the difference between a cast iron block and an aluminum block? what would the advantages be for each? BTW, this doesn't really fit into any certain category so i decided to post it in the highest volume section.
Old 08-11-2005, 09:38 PM
V T E C H's Avatar
V T E C H V T E C H is offline
Re: Engine Question
Well, a cast iron block (found in DSMs) is heavier, but can handel much more booste with out having to upgrade the internals. An aluminum block is lighter, but you cant booste it for shit. i think that pretty much sums it up. there are probably a lot of other pros and cons, but that is the biggest one i can think of
95 Integra GSR, I/h/e, 15" TSW wheels, short shift, front & rear swaybar, lowered 2", 93 GSR head & intake manifold
Old 08-11-2005, 10:40 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: Re: Engine Question
That doesn't make sense. Most stock Honda/Acura sleeves are cast iron. And the stronger internals is what allows them to be able to handle the boost, not the block. Think about it. When you are going to boost on a Honda engine, do you replace it with a cast iron block? No, you replace the sleeves, rods, pistons, and possibly the crank; so it can withstand the pressure.
Old 08-12-2005, 11:38 AM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: Engine Question
Cast is cheaper....but heavier
Aluminum is lighter....but costs more, and can warp more easily if overheated
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
