Old 08-11-2005, 03:40 PM
BigPanch's Avatar
BigPanch BigPanch is offline
Send a message via AIM to BigPanch
Question What should i use to remove the wire plugs?
Iv had a promblem romoving the wires they seem to be really tight on there and cant seem to take them out can any one give me any ways on how to take them out or should i buy the Pliers for removing plug wires?
02 Blue GTP
87 FireBird Formula
Need To See How They Do In The 1/4 Mile
Francisco
Old 08-11-2005, 06:10 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: What should i use to remove the wire plugs?
If you are putting new wires on the car then the plier method is ok, just don't bend the metal wire protectors as you will need them for the new wires. If you plan to reuse them then don't use pliers. You should try twisting them back and forth and then pulling them off. When you put them back on use dielectric grease in the boots they will make the plug wires come off much easier next time and will also seal the boots and keep the water out.
Old 08-12-2005, 01:43 AM
BigPanch's Avatar
koo thanks for the help.
02 Blue GTP
87 FireBird Formula
Francisco
