Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 08-11-2005, 02:09 PM
/\/\acGyver /\/\acGyver is offline
Looking for oil drain plug for 85 Isuzu transmission
Once I cut the spot welded one, I will need a replacement at the same time so I am looking for one, need asap. thanks.
Old 08-11-2005, 02:25 PM
84fiero123's Avatar
84fiero123 84fiero123 is offline
Re: Looking for oil drain plug for 85 Isuzu transmission
are the threads still good? if so try dealer or parts store, but being welded in i bet they are no good, so here is my suggestion.
go to the parts store and get a unuversal drain plug. it looks like a peace of rubber with a bolt in it. you remove or loosen the bolt slip the rubber into the hole then tighten the bolt, that expands the rubber on the inside and creats a seal.
technology is great when it works
but one big pain in the ass when it doesn't
Detroit Iron Rules, all the rest are just toys!
Old 08-11-2005, 05:57 PM
Ok I'll give it a shot, thanks
Old 08-13-2005, 06:06 PM
ctesla's Avatar
ctesla ctesla is offline
if the universal plug doesn't work,
you could chisel the spot welded one off, and replace with something similar to the B&M tranny drain plug;
basically a threaded pipe through the pan wall, gasket and nut on either side, with a threaded interior face, to plumb a smaller bolt into the drain hole.
or one of those Fram quick drain plug kits.
good luck
