Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 08-11-2005, 01:46 PM
paxmanhorn paxmanhorn is offline
Safe places to jack up a Sol?
I promise I searched the forum for the answer to this one before I posted this, but it seems like such a basic question that I was surpirised I didn't find the answer already. I am wanting to know if there are better places to jack up my Sol besides the approved 'tire changing' jack points. I know the Sol is a unibody design, and I just want to be certain I don't destroy anything in my haste to get the car up on stands so I can get under it. I would like to simply jack it from some centrally located spot so that I can lower onto two jackstands at once. Thanks again for your patience with me, I've only recently been bitten by the bug of working on my own car. Looking forward to your helpful replies,
Carl in TX
Old 08-11-2005, 05:08 PM
94SolGrl's Avatar
94SolGrl 94SolGrl is offline
Honda GODDESS/Global Mod
Send a message via AIM to 94SolGrl Send a message via MSN to 94SolGrl
Re: Safe places to jack up a Sol?
Up front: You'll see it if you look under the car. It's a spot on the radiator support that's reinforced. You'll know if you hit the wrong spot because your jack will go up but the car will stay down (don't worry, you're just bending plastic). The spot is off center, if you're looking at the car it's to the right, I believe.
In the back: Near the tow ring is a spot that you can jack the whole rear. As a warning, the car is VERY succeptible to sliding off, so I suggest you get the thing on jackstands as SOON as it clears them.
~*Emily*~
1995 Nissan 240SX - S15 whore
HOW TO POST PICS!
Old 08-11-2005, 05:14 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
also, anywhere on the frame will do.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 08-11-2005, 06:43 PM
ImSoYesterday ImSoYesterday is offline
Send a message via ICQ to ImSoYesterday Send a message via AIM to ImSoYesterday Send a message via MSN to ImSoYesterday Send a message via Yahoo to ImSoYesterday
I always set a jackstand up under the axle for some extra safety, so you can jack there as well.
Emily's personal boyslave
TSS: Rockin' the Bitches' Faces.
B16A2 engine with:
Short ram intake.
DC Sport header: Ceramic coated, 4-2-1.
Custom headerback exhaust with disconnected muffler.
MSD Ignition system. (With Enkei wires)
http://www.cardomain.com/id/imsoyesterday
Old 09-06-2005, 10:46 AM
nn048039 nn048039 is offline
Re: Re: Safe places to jack up a Sol?
The owners manual shows the 2 tow points on the front and the 1 on the back as Jacking positions. I use them all the time. The one on the back will jack up the whole rear, but the one's on the front will only do one side at a time.
Email me at "[email protected]" and I can send you a PDF file of the 92-95 Civic Factory manual which is the same as the Del-Sol. Same engines, Jacking points, etc.
