I have a 96 T-Bird. The turn signal abd the brake lights will not work. The center window brake light will work. Any help as to what is wrong.
Have you tried replacing the bulbs? |
No Turn Signals/Brake Lights
Tha front turn signals do not work either. The fuses are good. I do not think all four bulbs would be bad but I will check it.
Thanks Nice Bird |
Re: No Turn Signals/Brake Lights
I hope replacing the bulbs will cure your problem. Tracking down electrical gremlins can be frustrating. |
I feel foolish. The emergency flasher button was on. The flashers are not working but with it on the turn signal and brake lights will not work
Ok.. well trust me.. if your emergency flasher button was on and no brake lights or turn sigs.. then it wont be long before you have to replace the Multifunction switch. This is of course the whole turnsignal arm assembly which includes the emergency flashers also.... its doeable.. good luck
95 T-Bird 4.6 V-8 All still stock |
