Old 08-11-2005, 11:22 AM
ebproseller ebproseller is offline
Service Engine CODE !
Hi, I do the procedure to extract the service engine code from the computer.
When the light begins to flash here's what is the code extract ;
12473155
Wich number is the code, I saw a lot with 2 numbers, but 8 numbers !!!
Thanks for your help.
Old 08-11-2005, 06:29 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Service Engine CODE !
12 is start 55 is end of codes. The codes you have are actually 47 and 31. Code 47 indicates low charging circuit voltage, check the alternator, wiring to the alternator or the belt. Code 31 indicates you have a problem with the evaporative emissions circuit. You could have a loose gas cap or a bad solenoid on the evap. emissions system. I hope this clears it up.
Old 08-11-2005, 07:15 PM
pacamper pacamper is offline
Here is the link for the fault codes for 80 amd 90's Chryslaer, Dodge and Plymouths. http://www.allpar.com/fix/80s-codes.html
Hope it helps you out.
Old 08-12-2005, 08:37 AM
Thanks everybody, it helps me very much !
