Old 08-11-2005, 07:47 AM
intimidatordei intimidatordei is offline
Anti-lock brakes
I have a 1994 S-10 pick-up with a 4.3 Vortec. The anti-lock brake system continues to malfunction. I would like to completely remove the system from under the hood an make the brakes a conventional system. Could anyone give me info on what I will need to complete this project.
My truck is going to be for show, not a daily driver so I am trying to "clean-up" under the hood and since the anti-lock system doesn't work anyway I figured that was a good place to start.
Thank You
Old 08-11-2005, 09:34 AM
kmkommes kmkommes is offline
http://www.sytyarchives.com/howto/vi...dir=drivetrain
This is a how to remove ABS article at www.sytyarchives.com
Hope it helps.
Old 08-30-2005, 11:45 PM
ASE Tech1457 ASE Tech1457 is offline
Re: Anti-lock breaks
to disable the ABS simply pull the relay! the light will be on forever but if you remove the system it will be on too, more work than its worth to remove the system!!!
Old 08-31-2005, 01:00 AM
whitetrash982 whitetrash982 is offline
Send a message via AIM to whitetrash982
i hear tell if you unplug the whole ABS ecu , the ABS light wont even come on , but thats hear tell , i never tried it
