How do I know this 89 280XZ rearend is LSD
Hi - I recently started having vibration issues w/ my 510. I put the car on jacks and found the u-joint on the halfshaft loose. I looked at the junkyard and realized my 510m had aZX rearend. I found a ZX with good halfshafts. When I spun the wheels they both rotated in the same direction. I removed the cover and inspected the gears. They looked good and moved freely. There is a circular disk on one side. Is this the clutch? I dont see any cluthplates or springs. Thanx, Tim
You weren't making any sense to me..but I'm going to try to answer your question...to the best of my knowlege..and then maybe somebody that knows more will give you a better answer.
In my experience there are 2 good ways to tell if a diff is an LSD. 1: Put it up on jack stands and rotate one tire, if the other turns the same direction it is an LSD. if they turn opposite directions is not nesessarily an open diff or an LSD. 2: Put the car on the ground, get everything out from in front of it. Start it up. put it in first, rev it up and peel out, if both tires spin you got yourself an LSD, if not you most preobably don't.
1972 Datsun 510 2.0L 8-valve (all right!) SOHC i4 Weber 32/36 DGV carb 2" man-back exhaust Magnaflow muffler Lightened 240Z flywheel and 280Z clutch Did I mention, really fresh blue paint? That's all as of yet |
Re: How do I know this 89 280XZ rearend is LSD
