99 Head light crazing
I have a crazing problem on one of my lights (passenger side only) has anyone had any luck finding someone to repair this kind of problem or finding a kit to refinish the light?
Re: 99 Head light crazing
crazing problem? what the hell is that supposed to mean? explain more like what its doin an maybe 1 of us can give you some help.... u cant just expect us to know what your crazing term means... elaborate for us pls.
I think he means hazing problem... As in the plastic headlight cover is either oxidized or has a bunch of scratches on it...
Supplies:
1000-grit Sandpaper 2000-grit Sandpaper McGuires ScratchX Scratch Remover Spray Bottle filled with water Shop Towels 1. Pick a headlight to start on and spray it down with water. Dig out the 1000-Grit sandpaper and start sanding the headlight, keep it wet and wipe the plastic dust off frequently. Keep at it until the dust isn't yellow anymore and you can't feel any pits or corrosion on the lens. 2. At this point your headlight looks worse than when you started...it may have been foggy before but now you're wishing you had left them alone because they are clouded worse than ever before. Never fear. Dig out the 2000-Grit sandpaper and spray the headlight down, like before keep it wet, keep sanding and wiping and spraying until any minor imperfections come out, and all the scratches from the 1000-grit paper are smoothed out. 3. Yes I know they are still foggy. Wash them off completely and dry them thoroughly. Now grab that expensive tube of ScratchX and follow the directions, rub it on using tight circles and lots of elbow grease. Let it dry and then buff it off and look at your headlight. Has it ever looked better? No I didn't think so. 4. Repeat steps 1-3 above on the second headlight. I hope this helps relieve some of the aggrevation I had in trying to find a solution to my headlight issues. Mike
I guess you would call it hazing. It's not scratched but looks like UV damage. The plastic is starting to get an almost etched look to it in two or three spots on the lens exterior.
you have to bake your headlights in the oven before you can pop the plastic off
Daily Driver: 2004 Jeep Grand Cherokee Special Edition 1994 Mitsubishi 3000GT SL-TT Automatic - Black 3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods 1994 Mitsubishi 3000GT VR-4 - Black Intake & Boost Controller so far 2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods |
he never said to take the glass off, as the 99 are lexon and not glass. The 94 is the only year you bake them and pull the glass off to fix them. 95-99 follow the above instructions.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions. |
I thought it was 94-95 and maybe 96 but I heard 97 and up are lexon.
![]() Daily Cruiser - 1997 Mitsubishi 3000GT SL Weapon of Choice - 2006 Acura RSX Type-S New to the Family(Sold) - 1990 Nissan 240SX Good-bye to the almighty(Sold) - 1985 Toyota Corolla (AE86) +1,400HP/+1,300TQ RSX Type-S |
94 are glass, 95+ are lexon
Also you can remove the lexan covers if need be. I did it on 3 different lexans that had water in them. And for the wetsanding it self I would go 1000, then 1500, then 2000. going in smaller increments is what you want to do. The easiest way to keep an eye on your progressis wipe it dry and look for consistency. Another thing to keep in mind is to sand the same direction over the whole headlight. It will make it much more even.
are there any local retail stores I can go to and buy this McGuire's ScratchX Scratch Remover stuff? Or is it an online only thing?
1999 Pearl White 3000GT SL - Sold 1992 Dark Green 3000GT VR4 - Spun Bearing 2006 Black Suzuki Katana 600cc -hit from behind, totaled *JUST BOUGHT*2008 Red Mitsubishi Lancer ES - planning
Re: Re: 99 Head light crazing
Crazing Creation of fine cracks in material. The difference between microcracks and crazes is, that crazes can carry load. Craze can be described as a crack bridged by fibrils. It occurs mostly in amorphous, brittle polymers like PS, PMMA. The appearence of white color is caused by the presence of air in the craze. |
heck I got my tube of scratch-X at walmart. most auto parts stores will have it as well. its in the section of the store filled with creams and gels you rub your car with to make it feel good.
freggin sweet, I'll go take a look, I checked their website and couldn't find the mcGuires brand stuff, buuuut mebe the actual store has it....thanks!
it's confirmed, found mcguires scratch x at walmart
