Go Back   Automotive Forums Car Chat > Scion > tC
Old 08-10-2005, 09:02 PM
stjamesa stjamesa is offline
auto turbo kit
im a idiot i know but i don't know how to drive a stick and i want to turbo charge my automatic any kits to suggest is it even possible i'm looking to get about 310hp
Old 08-12-2005, 10:59 AM
silentscreams85's Avatar
silentscreams85 silentscreams85 is offline
Send a message via AIM to silentscreams85
https://www.tctunerz.com/index.php?c...cc3307ab7eb575
not alota turbo kits out yet
http://www.racingsolution.com/showpa...on=DisplayPart
be advised however. if your wanting to push over 300hp your gona have to work on engine internals ie lower compression pistons to accomodate the turbo, forged rods, larger fuel injectors,billet crank, its not just a matter of bolting on stuff it takes alot of preperation, time, patience and CASH!!!!!!!!!!! good luck.
K&N Intake
TRD axleback exhaust
Old 08-15-2005, 03:45 PM
TheQuietThings TheQuietThings is offline
Send a message via AIM to TheQuietThings
Re: auto turbo kit
if you're looking for a turbo kit with 310whp, you're not really going to have to worry about the fuel injectors or lowering the compression. the only thing you are really going to have to worry about is your transmission. the automatic transmission in the tC can handle around 250whp. so before bolting on a turbo kit, strengthen the transmission and if you can, buy a transmission cooler. heat is the transmissions biggest enemy. the injectors in the tC are plenty big to handle 300hp. you'll just have to watch your air fuel ratio and make sure you aren't abusing the transmission. if you're really looking to make the tC fly, I would definetely suggest an aftermarket torque converter.
2007 RS3.0 BlizzardPearl 5speed Scion tC
Old 12-13-2005, 02:41 AM
tscsciontc tscsciontc is offline
Send a message via AIM to tscsciontc Send a message via Yahoo to tscsciontc
Re: Re: auto turbo kit
TheQuietThings is definitely right about the torque converter. When the transmission went out in my automatic 1995 Prelude Si I upgraded to a JMO torque converter and it was much faster and the gear changes seemed more agressive.
Old 12-16-2005, 01:48 PM
doock87's Avatar
doock87 doock87 is offline
Send a message via AIM to doock87
stock injectors on a tc are definitely not big enough to safely support 300 hp. the factory option supercharger comes with a 5th injector. check the injector load % on a dyno chart to see what i mean.
