Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 08-10-2005, 08:32 PM
starkrice starkrice is offline
dim check engine light
I am having a big proble with my 92 accord-h22 my check engine light is dim but, all are good. The proble is that my car will not start, and when I take off the main relay its good but of curse the car will not start with out a relay, so I put it in, the same thing. when I take off my ecu its blank no engine light but all of the light are good. This thing is driving me nutssss 2weeks
Old 08-14-2005, 09:50 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Re: dim check engine light
Could be a bad ecu or check the ecu wiring to see if everything is connected right. If the problem occurs then take it to a local shop to diagnose it.
Old 08-15-2005, 12:29 AM
Re: Re: dim check engine light
Well check this out. when I was checking my sensors, I ran into 1 sensor that was gay, it was the idel control valve. When I unpluged it "DURING ACC" my fuel pump turnd on? I grounded my main relay more but still the same, but I can hear my fuel pump now that the sensor is disconned I'll try a p72 ecu to see if that's the problem.
